Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The camera lens is the main mechanism which allows the camera to capture images. The lens may need to be replaced if it has scratches or is cracked. These issues could lead to blurry photos or introduce unwanted lines in the photos. This guide walks you through the steps necessary to replace the lens. When following this guide, be sure to pay close attention to the order in which you remove the components. Also, be careful when removing the lens housing. The material is very delicate and is easily damaged.
Выберете то, что вам нужно
Remove plastic ring with the red strip around it.
Remove the 1.5 mm Phillips #1 screws which lie underneath the ring.
Remove the lens cover.
Remove the additional 1.5 mm Phillips #1 screws from underneath the lens cover.
Еще один человек закончил это руководство.
