Canon Powershot S110 Option Dial Replacement
Выберете то, что вам нужно
  1. Canon Powershot S110 Option Dial Replacement, Option Dial: шаг 1, изображение 1 из 2 Canon Powershot S110 Option Dial Replacement, Option Dial: шаг 1, изображение 2 из 2
    • Remove the battery by sliding open the battery cover on the bottom of the camera.
    • The battery must be removed to avoid shorting out any part of the camera.
  2. Canon Powershot S110 Option Dial Replacement: шаг 2, изображение 1 из 3 Canon Powershot S110 Option Dial Replacement: шаг 2, изображение 2 из 3 Canon Powershot S110 Option Dial Replacement: шаг 2, изображение 3 из 3
    • Remove the six screws by using a small Phillips head screwdriver.
    • Remove the two screws on the side of the camera on either side of the HDMI input panel.
    • Remove the two screws on the opposite side of the camera.
    • Remove the two screws on the bottom of the camera located on either side of the tripod mounting hole.
  3. Canon Powershot S110 Option Dial Replacement: шаг 3, изображение 1 из 1
    • Using an opening tool, carefully remove the outermost cover of the camera from its holders around the edges.
    • Once all of the clips around the plastic cover are released, the cover will lift off.
  4. Canon Powershot S110 Option Dial Replacement: шаг 4, изображение 1 из 2 Canon Powershot S110 Option Dial Replacement: шаг 4, изображение 2 из 2
    • Remove the two screws holding the top plastic bracket in place by using a Phillips head screwdriver.
    • Remove the screw holding down the lens cover.
    • Remove the screw located near the option dial next to the USB connections.
  5. Canon Powershot S110 Option Dial Replacement: шаг 5, изображение 1 из 1
    • Carefully lift the top panel of the camera by using a prying tool.
  6. Canon Powershot S110 Option Dial Replacement: шаг 6, изображение 1 из 1
    • Remove the screw at the center of the option dial by using a Phillips head screwdriver.
  7. Canon Powershot S110 Option Dial Replacement: шаг 7, изображение 1 из 2 Canon Powershot S110 Option Dial Replacement: шаг 7, изображение 2 из 2
    • Remove the underlying component that was attached to the now-removed screw by using a prying tool.
    • Remove the dial on the opposite side of the part using a prying tool.
Заключение
2 участников успешно повторили данное руководство.
akac92
Участник с: 07/14/15
298 Репутация
Автор 2 руководств
Команда
UW Tacoma, Team 1-2, Liner SU 2015 Участник UW Tacoma, Team 1-2, Liner SU 2015
UWT-LINER-SU15S1G2
4 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 1,102
