Введение
In this guide, the process of partially breaking down the Canon Powershot S110 and replacing the option dial will be explained in detail.
Выберете то, что вам нужно
Remove the battery by sliding open the battery cover on the bottom of the camera.
Remove the six screws by using a small Phillips head screwdriver.
Remove the two screws on the side of the camera on either side of the HDMI input panel.
Remove the two screws on the opposite side of the camera.
Remove the two screws on the bottom of the camera located on either side of the tripod mounting hole.
Using an opening tool, carefully remove the outermost cover of the camera from its holders around the edges.
Remove the two screws holding the top plastic bracket in place by using a Phillips head screwdriver.
Remove the screw holding down the lens cover.
Remove the screw located near the option dial next to the USB connections.
Remove the screw at the center of the option dial by using a Phillips head screwdriver.
Remove the underlying component that was attached to the now-removed screw by using a prying tool.
Remove the dial on the opposite side of the part using a prying tool.
2 участников успешно повторили данное руководство.
