Введение
The flash unit provides necessary lighting when not enough is available.
Инструменты
Запчасти
Детали не указаны.
Position the camera so that the bottom is facing up.
Remove the two 2.3mm screws beneath the name plate.
Remove the two 2.8 mm screws surrounding the threaded tripod mount.
Remove the two outer 3.2mm screws from the left side of the camera
Remove the two inner 3.7mm screws from the left side of the camera.
Pull the back face panel away from the front end of the body. This may take some wiggling and force.
After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
Remove the three (3.1mm) black screws that were behind the screen and battery box.
Remove the 3.3 mm screw from underneath the clear plastic flash unit on the front side.
Remove the clear plastic cover from the white wire by lifting off with finger.
Desolder the white wire.
Carefully pull the flash unit off the condenser. There is tape underneath, so some force may be required.
