Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
A simple guide for removing and replacing the memory card.
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Locate the sliding button labeled "CF OPEN."
Place your finger on the button and slide it in the direction of the arrow.
The side panel will flip open revealing the compact flash memory card.
Locate the gray button at the bottom of the open slot.
Place your finger on the button and push it down.
The memory card will pop out slightly.
Once a new memory card has been inserted close the swinging door and you're done.
