Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
A cracked LCD screen is a prevalent problem in digital cameras. But, before you spend money on a new LCD screen, make sure the camera still works by taking a few pictures and uploading them to your computer. A cracked LCD will not affect the quality of the pictures. You do not want to try to replace the LCD if something else is broken.
Выберете то, что вам нужно
Remove the 3.2 mm screw from the right side of the camera.
Remove the 2.2 mm screw from the right side of the camera.
Lift the side panel off.
Remove the 1.8 mm screw from underneath the side panel.
Remove the two 2.2 mm screws from the left side of the camera.
Lift the plate from the camera.
Next, peel the navigation buttons from the button panel and set them aside.
To free the LCD display, remove the .113 inch screw in the top left corner.
Then, rotate the screen clockwise until it lifts away from the camera.
To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
After disconnecting both cables, pull the screen away from the camera to remove it.
Еще один человек закончил это руководство.
