Введение
The outer case of the PowerShot SD550 is the part that takes the greatest beating. Every time the camera falls, it lands on its case. Some common problems include cracking and paint wear.
Выберете то, что вам нужно
Remove the 3.2 mm screw from the right side of the camera.
Remove the 2.2 mm screw from the right side of the camera.
Lift the side panel off.
Remove the 1.8 mm screw from underneath the side panel.
Remove the two 2.2 mm screws from the left side of the camera.
Lift the plate from the camera.
