Введение
You will need a #00 Phillips screwdriver to replace the camera's casing.
Make sure to remove the batteries before beginning the guide.
Выберете то, что вам нужно
Turn the camera to the side that has the attachment for the wrist strap.
Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
Remove the plastic subsection by prying it with your fingers.
The wrist strap attachment behind the subsection will come loose and may fall out.
Turn the camera over to the side opposite of the wrist strap.
Remove the two silver 3.4 mm screws with a #00 Phillips screwdriver.
Flip the camera upside down.
Remove the following screws with a #00 Phillips screwdriver.
One black 3.4 mm Phillips screw.
One silver 3.4 mm Phillips screw.
Place the camera on the side opposite of the wrist strap handle.
Then begin to pry the casing apart with both hands by applying pressure to the top and bottom of the camera.
Remove the small metal plate underneath the plastic covering and set aside. (It should be loosely attached)
5 участников успешно повторили данное руководство.
