Выберете то, что вам нужно
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Unplug the green and white plugs that connect the top panel to the top of the logic board.
Dislodge the tab above the lens.
Dislodge the tab at the back.
