Введение
The LCD screen is a monitor for the camera. It will display the photos before, during, and after capturing a picture. It also is used for changing settings easily. It does not operate in all camera modes. This guide will go through the steps needed to change the LCD screen if it is broken.
Выберете то, что вам нужно
Open the door. Release the catch by sliding it towards the side of the camera.
Then slide the door towards the front of the camera.
Remove AA batteries.
Using a fingernail or iFixit opening tools to pry up the battery cradle.
Remove CR1220 battery from the cradle.
Remove all four screws on the corners of the screen cover.
Gently pry open the cover with a fingernail or iFixit opening tool.
Remove two screws holding on the cover plate on the pivot.
Remove the cover plate using an iFixit opening tool.
Remove the two screws on top of the swivel arm. These two screws will be separated by the pivot point.
Remove grounding wire, then continue to remove the screws holding the screen and front cover plate on.
Еще один человек закончил это руководство.
