Выберете то, что вам нужно
Turn the camera so the back of it is facing you.
Pull the LCD screen towards you in order to open it,
Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
Unscrew the 3mm screw on the inner edge of the panel. This is easily done by rotating the screen to be perpendicular to the body of the camera, but be careful not to damage the wires or the circuit board.
The panel will fall right off
