Выберете то, что вам нужно
Turn the camera so the back of it is facing you.
Pull the LCD screen towards you in order to open it,
Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
Unscrew the 3mm screw on the inner edge of the panel. This is easily done by rotating the screen to be perpendicular to the body of the camera, but be careful not to damage the wires or the circuit board.
The panel will fall right off
Use spudger to remove the gold ribbon wire
This is easily done by lifting up the small black lock that holds the ribbon wire in place
Use tweezers to remove the second ribbon wire
This is best done by grasping at the base and pulling straight away from the circuit board
Lift the LCD screen out of the metal casing.
This is especially easy if you run the plastic opener along the bottom of the case
When the screen pops out, replace it with the new one.
Place the wires back on the circut board
The large one can be replaced by placing the wire gently in the slot and then pushing the lock into place
The smaller wire should be fed back into the board using tweezers to prevent bending at the edge.
To finish, follow the previous steps in reverse order to put everything back where it belongs
3 участников успешно повторили данное руководство.
6 Комментариев
Great instructions. Took me less time than estimated. Thanks
Thank you. Very clear instructions.
Hi, I just bought a display lcd screen. but it has only one ribbon, not have the little tiny one. What should I do?
Was any body able to find the replacement screen with 2 ribbon cables for the Canon SX30 IS having back light?
If so please share I’m in need of one for my camera.
Thanks
I’m also interested in where to buy the “two ribbon” display version. I just bought the wrong one with one ribbon and recognized that the “one ribbon” version ribbon also is a bit wider than the “two ribbon” version. I guess they changed the design and integrated the two ribbons into one (for assembly purpose I think).
washmann -
