Введение
This guide shows how to replace the printing mechanism for the Canon Selphy CP1200. This replacement may be necessary if the printing mechanism is faulty or is printing poor quality pictures while other device components are working and troubleshooting has failed. It is also a preliminary step for replacing both the battery leads and cooling fan.
Выберете то, что вам нужно
Gently pry open the top of the case from either the front or back.
Be careful in lifting the top assembly as it is attached to the motherboard at this point.
Инструмент, используемый на этом этапе:Tweezers$4.99
Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
The top assembly, containing both the LCD and buttons, will now be completely free
Detach the ribbon cable leading to the DC in port and battery leads.
Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
Open the side door and depress the ink cassette release.
Slide out and remove the ink cassette.
Unscrew the three 3mm PH000 screws securing the metal plate to the printing mechanism.
2 участников успешно повторили данное руководство.
