Canon Selphy CP1200 Print Mechanism Replacement
Выберете то, что вам нужно
  1. Canon Selphy CP1200 Print Mechanism Replacement, LCD/Buttons: шаг 1, изображение 1 из 1
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 Print Mechanism Replacement: шаг 2, изображение 1 из 1
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 Print Mechanism Replacement: шаг 3, изображение 1 из 1
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 Print Mechanism Replacement: шаг 4, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
  5. Canon Selphy CP1200 Print Mechanism Replacement, Motherboard: шаг 5, изображение 1 из 1
    • Detach the fan cable from the motherboard.
  6. Canon Selphy CP1200 Print Mechanism Replacement: шаг 6, изображение 1 из 1
    • Detach the ribbon cable leading to the DC in port and battery leads.
    • Tweezers may be useful.
  7. Canon Selphy CP1200 Print Mechanism Replacement: шаг 7, изображение 1 из 1
    • Unscrew the three 3mm PH000 screws from the motherboard.
  8. Canon Selphy CP1200 Print Mechanism Replacement: шаг 8, изображение 1 из 1
    • Disconnect the bundled cables leading to the printing mechanism.
  9. Canon Selphy CP1200 Print Mechanism Replacement: шаг 9, изображение 1 из 1
    • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
    • Tweezers may be useful due to the limited amount of space.
  10. Canon Selphy CP1200 Print Mechanism Replacement, Print Mechanism: шаг 10, изображение 1 из 2 Canon Selphy CP1200 Print Mechanism Replacement, Print Mechanism: шаг 10, изображение 2 из 2
    • Open the side door and depress the ink cassette release.
    • Slide out and remove the ink cassette.
  11. Canon Selphy CP1200 Print Mechanism Replacement: шаг 11, изображение 1 из 1
    • Unscrew the three 3mm PH000 screws securing the metal plate to the printing mechanism.
  12. Canon Selphy CP1200 Print Mechanism Replacement: шаг 12, изображение 1 из 1
    • Lift out the print mechanism of the printer case.
Заключение
2 человек успешно провели ремонт по этому руководству.
W Sherer
Участник с: 01/16/19
647 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team S1-G3, Crawford Winter 2019 Участник Eastern Washington University, Team S1-G3, Crawford Winter 2019
EWU-CRAWFORD-W19S1G3
3 членов
Автор 10 руководств
1 Комментарий к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 26
За последние 30 дней: 107
За всё время: 3,964
