Введение
This guide shows how to replace the cooling fan on the Selphy CP720. This is done to fix overheating problems caused by a faulty fan.
Выберете то, что вам нужно
Remove the four 8mm Phillips #1 screws from the bottom of the printer.
Unplug the fan from the circuit board by gently pulling on the wire connector at the base of the port.
Unscrew the two 8mm Phillips #1 screws from the fan.
Remove the fan from the panel.
Почти готово!
Заключение
