Введение
This repair is for when the speaker on your camera has either gone out or the audio is unrecognizable. There are no hazards to this repair as long as the battery and charger are not plugged into the camcorder. This repair to the device will be beneficial when recording a video clip with sound and want to play it back.
Выберете то, что вам нужно
Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
A hidden 4mm Philips #000 screw is shown under the black plug shown.
Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
Remove the three 6mm Philips #000 screws holding the black record piece.
Holding the full top piece remove the six 5mm Philips #000 screws holding the metal frame to the top piece.
