Введение
This guide will show you how to remove and replace the LCD display panel of the Vixia HF R62.
Выберете то, что вам нужно
Remove the strap by undoing the Velcro and pulling it through the thread points.
Remove the external battery pack by pressing down on the slide release and sliding it out.
On the side of the device, remove the following Phillips #000 screws:
One 3mm screw
One 5mm screw
Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out.
Remove the two 3mm Phillips #000 screws.
Remove the 4mm Phillips #000 screw.
Place the spudger under the tab shown.
While prying the tab up with the spudger, pull the case away.
Using a spudger, disconnect the ribbon cable connector from the PC board shown in the picture.
Using tweezers, disconnect the ribbon cable shown in the picture by pulling straight out.
Using a spudger, gently pry up the top tab on the ZIF connector. The wire will now disconnect with no force needed.
Using your fingers, firmly grasp both ends of the capturing device and gently pull the assembly straight out.
Remove the 3mm Phillips #000 screw holding the display's ribbon wire to the casing.
Undo the ZIF connector from the motherboard using a plastic spudger. Use the spudger to pry the small tab on top of the ZIF connector and the ribbon cable will fall free.
There is a small component of the ribbon cable clipped to the casing. Remove this by pulling it away from the casing with tweezers.
The ribbon cable is also looped around a piece of the casing under the motherboard. Unfasten this cable with tweezers by sliding down and then pulling out.
Remove the two 3mm Phillips #000 screws connecting to the display panel's hinges.
