Введение
This guide will help replace the internal battery and SD card reader, and opens up the central capturing unit to be disassembled
Выберете то, что вам нужно
Remove the strap by undoing the Velcro and pulling it through the thread points.
Remove the external battery pack by pressing down on the slide release and sliding it out.
On the side of the device, remove the following Phillips #000 screws:
One 3mm screw
One 5mm screw
Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out.
Remove the two 3mm Phillips #000 screws.
Remove the 4mm Phillips #000 screw.
Place the spudger under the tab shown.
While prying the tab up with the spudger, pull the case away.
