Введение
This guide will show you how to access and replace the lens of the camcorder. It will also act as a prerequisite to most of the internal components.
Выберете то, что вам нужно
Remove the strap by undoing the Velcro and pulling it through the thread points.
Remove the external battery pack by pressing down on the slide release and sliding it out.
On the side of the device, remove the following Phillips #000 screws:
One 3mm screw
One 5mm screw
Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out.
