Введение
This guide is the pre-requisite to all guides involving the replacement or repair of the internal components of the camera. Before you begin, please note that some screws will be covered with foam protectors.
Выберете то, что вам нужно
Remove the strap by undoing the Velcro and pulling it through the thread points.
Remove the external battery pack by pressing down on the slide release and sliding it out.
On the side of the device, remove the following Phillips #000 screws:
One 3mm screw
One 5mm screw
Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
