Введение
The panels of the Canon ZR70MC hold the camcorder together. The side panel in particular protects the main circuit board of the camcorder and also protects the imaging films located inside. This guide will show you how to take off the side panel, allowing easier access to the LED screen and lens component of the Canon ZR70MC. You should also have a designated location for the small parts of the camcorder so that you do not lose any pieces. Also, do not damage any wires that you come across.
Выберете то, что вам нужно
Turn the ZR70MC so that you can see the bottom of the camcorder.
Unscrew the 3.35 mm located in the top left portion of the camera.
Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
Remove the 2.65 mm screw.
Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
Locate and remove the two 3.35 mm screws.
Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
Turn the camcorder so that the back is facing you.
Remove the 3.75 mm screws from the back of the camcorder that hold the side panel in place.
Now that all of the screws are removed, gently pull off the side panel of the camcorder.
Gently pull the two black wires from their connections. These black wires are the only thing left connecting the side panel to the main body of the camcorder.
Gently pull the orange films out of their connections. This will allow you access to all components of the main body.
Один комментарий
How to fix the start/stop button when it doesn't responding.
