Введение
This guide will assist in removing wrinkles and creases from caps. Due to the shape of a cap, it is impossible to use an iron to remove wrinkles and creases that may form due to how it has been stored after a long period of time.
The restoration is quick, easy and affordable using few household items.
Many caps are made with different materials, therefore, some items noted in this guide may be optional.
- Bowl/Pot - Can be used to provided extra pressure to the plastic bags while holding the bags in place.
- Hairspray - The hairspray can be used on any area of the cap, it is used to help hold some of the firmer parts of the cap in place and resume its shape. Examples of common caps that will benefit from this is baseball caps and snap backs.
Выберете то, что вам нужно
Wash the cap using an old toothbrush to remove residue and stains.
Place plastic bags into the cap ensuring enough bags are used to give the cap some shape.
Use a bowl or small pot to add pressure to the plastic bags and hold them in place.
Set the cap aside to dry naturally. You can use an indoor fan to assist with this process.
2 участников успешно повторили данное руководство.
