Введение
If you need to replace the outside casing, follow this guide. The outside casing is essential to keeping everything inside in place, and protecting the internal structures of the device. If there is cosmetic damage or significant disfigurement, replacement of the metal outside casing is suggested. For this guide, you will need the Torx Security T10 Bit Screwdriver as well as the extension bit.
Запчасти
No parts specified.
  1. Twist the top plastic container to the left counterclockwise. Pull upwards to remove.
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
  2. Twist the top burr to the left counter clockwise. Pull upwards to remove. Pull upwards to remove.
    • Twist the top burr to the left counter clockwise.
  3. Flip entire device upside down. Remove two rubber coverings on the back of the device.
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
  4. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Купить сейчас
    iPhone X Fix Kits
    Купить сейчас
  5. Remove four 11.59mm T10 screws. The screws will have small circular washers under them. Put them aside for reassembly.
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
  6. Lift the metal outside casing off the black base. Flip the outside casing forward so you have access to the inside of it. Flip the outside casing forward so you have access to the inside of it.
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
  7. Remove one 11.59mm T10 screw. Let the green wire fall, or place somewhere so it doesn't get in the way. There will be a small metal retainer and washer, put them aside for reassembly.
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
  8. Remove two 11.59mm T10 screws. Remove two 11.59mm T10 screws. Remove two 11.59mm T10 screws.
    • Remove two 11.59mm T10 screws.
  9. Remove the time/on switch by pulling upwards. Remove the time/on switch by pulling upwards.
    • Remove the time/on switch by pulling upwards.
Заключение
Nina Mackin
Участник с: 09.10.2018
366 Репутация
Автор 2 руководств
Команда
USF Tampa, Team S1-G1, Leahy Fall 2018 Member of USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 16
За всё время: 144
