Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If you need to replace the timer/on switch, follow this guide. The timer/on switch is essential to how long the coffee beans take to turn into coffee grounds. For this guide, you will need the Torx Security T10 Bit Screwdriver, the extension bit, and a soldering iron.
Выберете то, что вам нужно
Twist the top plastic container to the left counterclockwise.
Pull upwards to remove.
Flip entire device upside down.
Remove two rubber coverings on the back of the device.
Lift the metal outside casing off the black base.
Flip the outside casing forward so you have access to the inside of it.
Remove one 11.59mm T10 screw.
Let the green wire fall, or place somewhere so it doesn't get in the way.
Strip the two wires of their black covering connecting them to the black box.
Solder the two cords holding in the blue and white wire in the black timer box.
3 участников успешно повторили данное руководство.
4 Комментариев
do you know where I can get a new black timer box?
Where can I purchase a timer/on switch?
Same question here, where can I buy this part?
Just piling on,has anyone found where to buy the Timer switch?
