Введение
In this guide, you will be instructed on how to adjust and synchronize the output of the two carburetors.
Инструменты
Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner.
Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
Start the engine
Allow time for the engine to warm up completely
Attach carburetor synchronization tool to one of the carburetors
Observe the relative reading, and remember it.
This reading is a measurement of the airflow speed
Set the synchronization device on the other carburetor.
Using a Flathead screw-driver, twist the idle speed screw in to raise the flow, and out to lower it.
Recheck both carburetors and adjust as needed to get the flow as equal as possible.
Now, the idle mixture screws must be adjusted.
Turn both screws in, or out an 1/8 or a turn at a time until the fastest idle speed is achieved.
Finally, raise or lower the idle speed screws until the idle speed is about 550 RPM
Rotate the aircleaner back to its original position, and re-tighten the 3/8 nuts on the retainers
Congratulations, your Corvair should now idle properly. If the Carburetors are still not operating properly, then the linkage is not synchronized, or they are in need of repair or rebuild. (A linkage adjustment and rebuild guide will be made soon!)
25 участников успешно повторили данное руководство.
Один комментарий
Bonjour,
Ma corvair a 4 carburateurs.
Est-ce que le ralenti se règle individuellement sur chaque ?
Merci
