Введение
Does your quadrocopter not power on after you already charged the battery? This guide will show you how to the replace the damaged or defective battery in 3 quick and easy steps.
Flip the quadrocopter over so that the underside of the device is facing up.
Unplug the battery cable from the socket on the quadrocopter.
Push the battery upward with your thumbs to loosen it from the tight slot until your thumbs can not reach the bottom of the battery anymore.
