Введение
A weak or damaged motor might be the reason your quadrocopter is unable to fly properly. This guide will show you how to replace any of the four motors
Выберете то, что вам нужно
Flip the quadrocopter over so that the underside of the device is facing up.
Unplug the battery cable from the socket on the quadrocopter.
Push the battery upward with your thumbs to loosen it from the tight slot until your thumbs can not reach the bottom of the battery anymore.
Using the JIS #00 screwdriver, hold the rotor blade still and unscrew the 4.762mm screw in the center of the blade.
With the PH1 screwdriver, unscrew the four 7.1mm screws located underneath the quadrocopter.
Pull the base out and set the foam piece aside
Using the PH0 screwdriver, unscrew the 3.2 mm screw on the base.
Pull the rotor leg out from the base
Using the PH0 screwdriver, unscrew the 4 mm screw where the leg meets the motor case/ rotor stand.
Pull the leg apart from the motor case/ rotor stand
Using the metal spudger of your choice, remove the clip at the top of the motor.
Use the thinner side of the spudger to push the motor through and out of the case.
