Casdon Dyson Ball Air Cylinder Motor Replacement
Выберете то, что вам нужно
  1. Casdon Dyson Ball Air Cylinder Motor Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Air Cylinder Motor Replacement: шаг 2, изображение 1 из 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Air Cylinder Motor Replacement, Casdon Dyson Ball Disassembly: шаг 3, изображение 1 из 1
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Air Cylinder Motor Replacement: шаг 4, изображение 1 из 1
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Air Cylinder Motor Replacement: шаг 5, изображение 1 из 1
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Air Cylinder Motor Replacement: шаг 6, изображение 1 из 1
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Air Cylinder Motor Replacement: шаг 7, изображение 1 из 1
    • Remove beads from the container.
  8. Casdon Dyson Ball Air Cylinder Motor Replacement, Air Cylinder Motor: шаг 8, изображение 1 из 1
    • Remove four 9.2mm (0.32 in) screws on bottom of air cylinder motor mount using the PH00 screwdriver.
  9. Casdon Dyson Ball Air Cylinder Motor Replacement: шаг 9, изображение 1 из 1
    • Remove one 11.5mm (0.45 in) screw in battery compartment using the PH00 screwdriver.
  10. Casdon Dyson Ball Air Cylinder Motor Replacement: шаг 10, изображение 1 из 1
    • Remove the red fan from the motor by pulling the red fan away from the bead cylinder motor compartment.
  11. Casdon Dyson Ball Air Cylinder Motor Replacement: шаг 11, изображение 1 из 1
    • Cut wires connected to faulty motor using a set of wire cutters.
  12. Casdon Dyson Ball Air Cylinder Motor Replacement: шаг 12, изображение 1 из 2 Casdon Dyson Ball Air Cylinder Motor Replacement: шаг 12, изображение 2 из 2
    • Remove and replace faulty air cylinder motor.
    • Solder new air cylinder motor's wires to the vacuum's wires which were previously cut.
Заключение
Еще один человек закончил это руководство.
Seldon Price
Участник с: 11/07/17
612 Репутация
Автор 5 руководств
Команда
IUPUI, Team S3-G5, Harley Fall 2017 Участник IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 членов
Автор 10 руководств
Один комментарий
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 276
