Введение
By using the PH00 screwdriver, this guide will show how to remove the batteries from the Casdon Dyson Ball.
Выберете то, что вам нужно
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Remove batteries from the vacuum by pulling them out and away from the vacuum.
Почти готово!
Заключение
