Введение
If you are having issues with the responsiveness or functionality of the key pad on your Casio Cassiopeia E-125, this guide will walk you through the process in 10-15 minutes.
In Step 9, proceed with caution: Potential for device damage. Do not pull apart the wires connecting the outer case.
Выберете то, что вам нужно
Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
Lift the tab on the motherboard and pull out the ribbon cable.
After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
Use the Phillips #00 screwdriver and remove the five screws from the daughterboard.
