Введение
This guide shows how to remove the front case from the rest of the camera. You may have to do this to replace a damaged front cover or to access the inner parts of the camera.
Запчасти
No parts specified.
  1. Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom.
    • Locate 12 screws. Four on the left, four on the right, and four on the bottom.
  2. iPhone X Fix Kits
    Warranty up? No worries, we’ve got the fix.
    Купить сейчас
    iPhone X Fix Kits
    Купить сейчас
  3. Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
    • Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
  4. Separate the front case from the body of the camera.
    • Separate the front case from the body of the camera.
Заключение
Patrick Stalwick
Участник с: 18.04.2012
112 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 9-45, Regan Spring 2012 Member of Cal Poly, Team 9-45, Regan Spring 2012
CPSU-REGAN-S12S9G45
7 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 4
За 30 дней: 4
За всё время: 303
