Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows how to remove the front case from the rest of the camera. You may have to do this to replace a damaged front cover or to access the inner parts of the camera.
Выберете то, что вам нужно
Locate 12 screws. Four on the left, four on the right, and four on the bottom.
Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
