Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
Remove the four 3.7 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
