Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
Remove the four 3.7 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
Remove the two 1.68mm screws located on the motherboard, using a #00 Phillips screwdriver.
Using the plastic opening tool, pry the battery case clamps (located on front of the camera) so that the bottom will come loose.
Detach the inner orange strip from the motherboard to the lens by inserting the plastic opening tool under the tab and llifting up.
Fully remove the motherboard from the lens.
It will be still be attached by wires and a different orange strip.
2 участников успешно повторили данное руководство.
Один комментарий
I veganlover loved this guide! Although it wasn’t vegan enough
