Введение
If your lens have cracked, stopped working, or malfunctioned in any other way, you may need to replace the lens. This guide will isolate the lens so that it can be replaced or investigated.
Выберете то, что вам нужно
Remove the strap from the camera by pulling the thin cord out, creating a small loop, then pushing the thicker cord back through this loop.
Remove the two Phillips screws (2.83 mm) from the left side panel of the camera casing.
The left panel can now be removed. However, one piece of tape attaches it to the camera, so a spudger may be required to ease the panels off.
Repeat for the right side panel of the camera.
Remove the two Phillips screws (2.79 mm) on the left side of the camera where the metal panel used to be.
Repeat for the two Phillips screws (2.79 mm) right side of the camera.
With the LCD screen facing up towards you, start at the bottom of the camera and gently pull off the back of the casing.
With the front side (with the lens) facing up towards you, start at the bottom of the camera and gently pull off the front of the casing.
Slide the labeled piece toward the LCD screen and release.
The tab will spring open.
Look at the bottom of the camera. Take out the Phillips screw (1.77 mm) holding on the bottom plastic piece.
The bottom plastic piece is held on to the main frame of the camera only by two thin wires.
Using a screwdriver, push the metal tab toward the center of the circuit board.
As you pull the lens up and out of the casing, push the hook in the lower right hand corner of the lens out of the way.
At this point the lens should be connected to the camera solely by two orange plastic strips.
Using tweezers or your finger nails, pull up the brown flaps where the two orange film strips connected to the lens meet the circuit board.
Use the tweezers to pull the orange film strips out of the port. It should come out easily.
There are two additional film strips connected to the circuit board that do not need to be removed. These are connected to the side of the circuit board that is opposite to the lens
You can now remove the lens completely. There should not be anything else holding it in place.
Turn the lens over
On the back are four screws. Remove the two silver phillips screws (4.36 mm) from the back of the lens.
Remove the now loose orange piece from the back of the lens and set it aside.
The lens is now ready to cleaned and maintained or replaced with a new one.
2 участников успешно повторили данное руководство.
