Casio Exilim EX-Z70 Memory Card Replacement
  1. Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: шаг 1, изображение 1 из 3 Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: шаг 1, изображение 2 из 3 Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: шаг 1, изображение 3 из 3
    • Orient the camera with the lens facing to the right and the bottom of the camera toward you.
    • Grasping the camera tightly, press downward firmly on the piece with the label and slide it towards the LCD screen (to the left).
    • The flap will then swing upward.
  2. Casio Exilim EX-Z70 Memory Card Replacement: шаг 2, изображение 1 из 2 Casio Exilim EX-Z70 Memory Card Replacement: шаг 2, изображение 2 из 2
    • Push down on the memory card (located behind the battery) and then release pressure completely.
    • The memory card will automatically rise part way out of its compartment.
    • Grasp the memory card on each side and simply slide it out of its compartment to remove it.
  3. Casio Exilim EX-Z70 Memory Card Replacement: шаг 3, изображение 1 из 3 Casio Exilim EX-Z70 Memory Card Replacement: шаг 3, изображение 2 из 3 Casio Exilim EX-Z70 Memory Card Replacement: шаг 3, изображение 3 из 3
    • If your memory card is locked, there is a metal slider on the left side that can be moved up to unlock the memory card.
Заключение
2 участников успешно повторили данное руководство.
Paul Fallon
Участник с: 04/10/12
141 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 17-28, Amido Spring 2012 Участник Cal Poly, Team 17-28, Amido Spring 2012
CPSU-AMIDO-S12S17G28
4 членов
Автор 14 руководств
2 Комментариев
My Casio camera works great until I insert the memory card. When it doesn't have the memory card, it turns on, the lenses come out and everything but as soon as I insert the memory card, the lenses will come out have way, and then the camera shuts off like that. The only way to get the lenses to get inside and the camera to turn on, is to remove the memory card. HELP ME PLEASE!
Miriam - Ответить
I have a similar issue. My camera won’t recognize the SD card! It’ll turn on & take pic’s in the Memory area, but them it’s FULL after a few. Isn’t there something that can be done?
I see NO ONE HAS ANSWERED THE LAST PERSONS QUESTION….????????????
Lynn Lehr - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 52
За всё время: 3,383
