Casio F-91W Battery Replacement
Выберете то, что вам нужно
  1. Casio F-91W Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Place the watch with the digital display facing downward, revealing the back cover.
  2. Casio F-91W Battery Replacement: шаг 2, изображение 1 из 3 Casio F-91W Battery Replacement: шаг 2, изображение 2 из 3 Casio F-91W Battery Replacement: шаг 2, изображение 3 из 3
    • Using a small Phillips head screwdriver, remove the four screws connecting the case back to the watch case.
    • Place the screws in a small bag or container for safekeeping while you replace the battery.
    • Be especially careful while removing the screws to avoid dropping any.
    • Gently remove the case back and set aside.
  3. Casio F-91W Battery Replacement: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Use a pair of tweezers to gently remove the gasket from the bevel surrounding the watch movement.
    • You may want to take a picture of the position of the gasket prior to removing it to help you remember the gasket orientation.
  4. Casio F-91W Battery Replacement: шаг 4, изображение 1 из 2 Casio F-91W Battery Replacement: шаг 4, изображение 2 из 2
    • Gently pry the watch movement out of the case from the upper right corner. Use as little force as possible.
    • Once you have pried the watch movement up slightly from the case, you can gently remove it with your fingers.
    • Now that you are touching the internals of the watch, you should use finger cots or gloves (if possible) to keep the movement clean and avoid rust.
  5. Casio F-91W Battery Replacement: шаг 5, изображение 1 из 2 Casio F-91W Battery Replacement: шаг 5, изображение 2 из 2
    • Gently disengage the hinges holding the battery cover onto the rest of the watch movement.
    • There are four hinges to disengage—two on each side of the movement. Make sure you disengage all four before attempting to remove the battery cover to avoid damaging the movement.
  6. Casio F-91W Battery Replacement: шаг 6, изображение 1 из 2 Casio F-91W Battery Replacement: шаг 6, изображение 2 из 2
    • Remove the battery cover and set aside, exposing the drained battery.
    • Make sure to note the orientation of the battery. If you do not replace the battery in the correct orientation, the watch will not receive power.
  7. Casio F-91W Battery Replacement: шаг 7, изображение 1 из 3 Casio F-91W Battery Replacement: шаг 7, изображение 2 из 3 Casio F-91W Battery Replacement: шаг 7, изображение 3 из 3
    • Gently remove the old battery and replace it with the new battery.
    • If you have not replaced the battery in your Casio F-91W before, the battery may be secured with a small piece of black adhesive (visible on the left side of PCB in the second picture).
    • Make sure the replacement battery rests securely between the four white plastic posts circled in the third picture.
Заключение
4 человек успешно провели ремонт по этому руководству.
Ryan Hill
Участник с: 03/05/23
253 Репутация
1 руководство автора
Команда
University of North Texas, Team 2-1, Raign Spring 2023 Участник University of North Texas, Team 2-1, Raign Spring 2023
UNT-RAIGN-S23S2G1
2 членов
Автор 5 руководств
1 Комментарий к руководству
Fantastic guide, thank you! On reassembling I did find I had trouble getting the watch movement back in the case. This was because the buttons were catching on the button arms. To solve it I used a flat head to push the buttons out, from the inside, as far as they would go and with a bit of persuassion it all went back in. Thanks again :-)
Doug - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 32
За последние 7 дней: 223
За последние 30 дней: 1,006
За всё время: 27,293
