Casio FX-115MS Motherboard and Screen Replacement
Выберете то, что вам нужно
  1. Casio FX-115MS Motherboard and Screen Replacement, Back Plate: шаг 1, изображение 1 из 1
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
  2. Casio FX-115MS Motherboard and Screen Replacement: шаг 2, изображение 1 из 3 Casio FX-115MS Motherboard and Screen Replacement: шаг 2, изображение 2 из 3 Casio FX-115MS Motherboard and Screen Replacement: шаг 2, изображение 3 из 3
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
  3. Casio FX-115MS Motherboard and Screen Replacement, Battery: шаг 3, изображение 1 из 2 Casio FX-115MS Motherboard and Screen Replacement, Battery: шаг 3, изображение 2 из 2
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
  4. Casio FX-115MS Motherboard and Screen Replacement, Motherboard and Screen: шаг 4, изображение 1 из 2 Casio FX-115MS Motherboard and Screen Replacement, Motherboard and Screen: шаг 4, изображение 2 из 2
    • Using the plastic spudger, carefully pry the battery terminals from the front plate. If the plastic spudger is too weak for prying out the terminals, use the small metal spudger.By Carefully bending and/or prying the little teeth on the terminals upwards you can easily remove them.
  5. Casio FX-115MS Motherboard and Screen Replacement: шаг 5, изображение 1 из 3 Casio FX-115MS Motherboard and Screen Replacement: шаг 5, изображение 2 из 3 Casio FX-115MS Motherboard and Screen Replacement: шаг 5, изображение 3 из 3
    • Using the small metal spudger. Carefully pry around the edge of the solar panel until it becomes loose. Then simply pull it from its socket using your hands.
  6. Casio FX-115MS Motherboard and Screen Replacement: шаг 6, изображение 1 из 2 Casio FX-115MS Motherboard and Screen Replacement: шаг 6, изображение 2 из 2
    • Using a PH0 phillips screwdriver, unscrew the four, 4mm, pan head screws from the motherboard.
  7. Casio FX-115MS Motherboard and Screen Replacement: шаг 7, изображение 1 из 3 Casio FX-115MS Motherboard and Screen Replacement: шаг 7, изображение 2 из 3 Casio FX-115MS Motherboard and Screen Replacement: шаг 7, изображение 3 из 3
    • Carefully lift the motherboard, screen, solar panel, and battery terminal combination from the front plate. Start from the motherboard and lift at an angle toward the solar panel.
Заключение
8 участников успешно повторили данное руководство.
Lindsey Griffin
Участник с: 10/04/16
448 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 2-2, Nance Fall 2016 Участник USF Tampa, Team 2-2, Nance Fall 2016
USFT-NANCE-F16S2G2
4 членов
Автор 15 руководств
Один комментарий
where can i find an lcd for this exact calculator?
Ahmad Alsabbagh - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 11
За последние 30 дней: 48
За всё время: 3,034
