Введение
Casio Advanced Scientific FX-991CW Battery Replacement.
First, take the protective cover off the calculator.
Then, turn the calculator over.
Remove the Philips screw that holds the battery cover in place in the top-right corner.
Then lift the cover off by lifting the right side of the cover up, and slide it out.
Take a pointy, flat tool, like a flathead screwdriver, to pry the battery out of the compartment.
Insert the new battery into the calculator by sliding it into place, then pushing it down, to ensure a good connection.
Slide the battery cover into place.
Then install the screw.
Tighten the screw.
NOTE: BELOW THIS GUIDE, THERE IS A NOTE THAT SAYS "TO REASSEMBLE THIS DEVICE, FOLLOW THESE DIRECTIONS IN REVERSE ORDER." DO NOT FOLLOW THAT STEP, AS THIS GUIDE IS COMPLETE!
Еще один человек закончил это руководство.
