Casio G’zOne Commando 4G LTE Camera Replacement
Выберете то, что вам нужно
  1. Casio G’zOne Commando 4G LTE Camera Replacement, Motherboard: шаг 1, изображение 1 из 1
    • First, you are going to want to take out the two front screws from the device.
    • The screws are 4mm in length and require a Y0 bit to remove
  2. Casio G’zOne Commando 4G LTE Camera Replacement: шаг 2, изображение 1 из 1
    • Using the same screw head, remove the back four screws from the device.
  3. Casio G’zOne Commando 4G LTE Camera Replacement: шаг 3, изображение 1 из 2 Casio G’zOne Commando 4G LTE Camera Replacement: шаг 3, изображение 2 из 2
    • You should have taken out six screws (two from the front, four from the back). Once you do this, you will have to separate the front and back casing of the phone using a spudger or pry tool.
  4. Casio G’zOne Commando 4G LTE Camera Replacement: шаг 4, изображение 1 из 1
    • Now, you have six more screws to unscrew (three on each side). They are all the same size but smaller than the first six we took off.
    • These screws are 4mm in length and require a PH00 tip to remove.
  5. Casio G’zOne Commando 4G LTE Camera Replacement: шаг 5, изображение 1 из 1
    • Once you unscrew all six screws, you can easily separate the plastic shell with your hands.
  6. Casio G’zOne Commando 4G LTE Camera Replacement: шаг 6, изображение 1 из 2 Casio G’zOne Commando 4G LTE Camera Replacement: шаг 6, изображение 2 из 2
    • Again, there are six more (and even smaller) screws to take out. Additionally, you have to disconnect a small wire plugged into the motherboard.
    • These screws are 2mm in length and require a PH000 tip to remove.
  7. Casio G’zOne Commando 4G LTE Camera Replacement: шаг 7, изображение 1 из 2 Casio G’zOne Commando 4G LTE Camera Replacement: шаг 7, изображение 2 из 2
    • After removing the screws carefully separate the motherboard from the shell with the spudger.
  8. Casio G’zOne Commando 4G LTE Camera Replacement, Camera: шаг 8, изображение 1 из 1
    • In order to remove the camera, carefully disconnect the wires with the metal spudger.
  9. Casio G’zOne Commando 4G LTE Camera Replacement: шаг 9, изображение 1 из 3 Casio G’zOne Commando 4G LTE Camera Replacement: шаг 9, изображение 2 из 3 Casio G’zOne Commando 4G LTE Camera Replacement: шаг 9, изображение 3 из 3
    • After disconnecting the wires, remove the camera by putting slight pressure of the optical camera lens. The camera the will pop out of the motherboard.
Заключение
Еще один человек закончил это руководство.
Keith Hickey
Участник с: 10/29/15
428 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 1-9, Miles Fall 2015 Участник UMass Dartmouth, Team 1-9, Miles Fall 2015
UMASSD-MILES-F15S1G9
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 14
За всё время: 421
