Casio G’zOne Commando 4G LTE Sim Card Replacement
Выберете то, что вам нужно
  1. Casio G’zOne Commando 4G LTE Sim Card Replacement, Battery: шаг 1, изображение 1 из 1
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Sim Card Replacement: шаг 2, изображение 1 из 2 Casio G’zOne Commando 4G LTE Sim Card Replacement: шаг 2, изображение 2 из 2
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
  3. Casio G’zOne Commando 4G LTE Sim Card Replacement, Sim Card: шаг 3, изображение 1 из 1
    • After removing the battery you will find a port that is labeled SIM directly beneath where the battery was sitting.
  4. Casio G’zOne Commando 4G LTE Sim Card Replacement: шаг 4, изображение 1 из 1
    • In order to remove the SD card lift the tab that is located directly to the left of the card. Then slide the SD card out of its port and remove it from the cell phone.
Заключение
3 участников успешно повторили данное руководство.
Keith Hickey
Участник с: 10/29/15
428 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 1-9, Miles Fall 2015 Участник UMass Dartmouth, Team 1-9, Miles Fall 2015
UMASSD-MILES-F15S1G9
3 членов
Автор 10 руководств
2 Комментариев
My Casio C811 will not go to a browser, keeps saying no network connection. I am in an area that I have had connection with no problems before. The phone did some sort of reset on it own and now wont access any browser, google, Facebook ect. I have check the network setting and they appear OK. Any suggestions
bernmntsa - Ответить
How do I unlock my Casio Commando C811 to use with non-verizon SIM…!?
Alrn Arun - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 26
За всё время: 4,557
