Casio LK-170 Key Replacement
Выберете то, что вам нужно
  1. Casio LK-170 Key Replacement, Key: шаг 1, изображение 1 из 3 Casio LK-170 Key Replacement, Key: шаг 1, изображение 2 из 3 Casio LK-170 Key Replacement, Key: шаг 1, изображение 3 из 3
    • You will be removing 17 11mm screws with a JIS-1 screwdriver to detach the back of the keyboard from the front.
    • You will begin by removing 4 screws on each side of the piano, circled in red.
    • You will then remove the four screws that are a little hidden, circled in orange.
    • Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
  2. Casio LK-170 Key Replacement: шаг 2, изображение 1 из 2 Casio LK-170 Key Replacement: шаг 2, изображение 2 из 2
    • After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
    • You should now see the screws holding the keys in place.
    • There are five 18mm screws per section of keys.
    • With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
  3. Casio LK-170 Key Replacement: шаг 3, изображение 1 из 2 Casio LK-170 Key Replacement: шаг 3, изображение 2 из 2
    • You will be able to pick up the white keys with your hands and remove them.
Заключение
2 человек успешно провели ремонт по этому руководству.
Samantha Baker
Участник с: 01/24/17
443 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 13-2, Banghart Winter 2017 Участник Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 членов
Автор 5 руководств
1 Комментарий к руководству
This guide also works for the Casio LK-175.
The keys are in small groups and you will need to purchase the correct ones. Unfortunately, the ones I received from a seller did not match. I think he thought the part was compatible between my keyboard and the one he pulled them from. I very carefully tried super-gluing the key back onto it's section and so far so good (a few hours). Hopefully, the repair will hold.
Thank you for the guide Samantha.
Steve Ferrel - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 23
За всё время: 2,694
