Casio MarineGear wristwatch battery Replacement
Выберете то, что вам нужно
  1. Casio MarineGear wristwatch battery Replacement, Opening the back: шаг 1, изображение 1 из 2 Casio MarineGear wristwatch battery Replacement, Opening the back: шаг 1, изображение 2 из 2
    • Use a Phillips #00 to remove the 4 screws holding the back.
  2. Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: шаг 2, изображение 1 из 3 Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: шаг 2, изображение 2 из 3 Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: шаг 2, изображение 3 из 3
    • Use the tweezers to remove the plastic ring that aligns the movement.
    • In this case the watch didn't have a battery installed, but to get the battery out you have to use the tweezers and unhook the latch holding the battery in place.
    • The correct battery for this watch is CR2025 3V button cell.
  3. Casio MarineGear wristwatch battery Replacement, Install new battery: шаг 3, изображение 1 из 2 Casio MarineGear wristwatch battery Replacement, Install new battery: шаг 3, изображение 2 из 2
    • Insert the new battery into it's place.
    • Latch the battery hook back into it's place, securing the battery.
    • Turn the movement over to verify the watch is now working.
    • You may have to touch the AC (negative) side of battery, to the metal grounding plate. (It's stated on the white label and marks are very clear).
  4. Casio MarineGear wristwatch battery Replacement, Reassemble the watch: шаг 4, изображение 1 из 3 Casio MarineGear wristwatch battery Replacement, Reassemble the watch: шаг 4, изображение 2 из 3 Casio MarineGear wristwatch battery Replacement, Reassemble the watch: шаг 4, изображение 3 из 3
    • Make sure the rubber gasket is placed correctly in it's groove, as it is there for water resistance.
    • Place the back cover on and fasten the 4 Phillips #00 screws securing the back plate.
    • Set the time and date, and your watch is now in working order again.
Заключение
Reassembly is detailed in the guide
Geir Ove Andersen
Участник с: 06/06/22
7 740 Репутация
Автор 5 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 536 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 27
За всё время: 1,016
