Введение
This guide will show you how to remove, clean, and replace the button clusters on the keyboard's front black panel
Выберете то, что вам нужно
Place keyboard key side down
Remove 23 16mm screws with Phillips #2 screwdriver
Pull black panel away from keyboard and place face-up on keys
Remove all screws from circuit panel with Phillips #1 and #2 screwdrivers in order to remove all 18 16mm and 18mm screws.
Pull circuit panel away from black panel
Set circuit panel out of the way
Remove/clean button cluster
Reassemble with new/cleaned button cluster
