Введение
This guide will show you how to remove, clean, and replace the black keys of the keyboard
Выберете то, что вам нужно
Place device face-down
Remove 23 16mm screws with Phillips #2 screwdriver
Remove speaker(s) if necessary to access desired key section(s)
Use Phillips #2 screwdriver to remove two 16 mm screws (circled in red)
Pop wires out of plastic holders so speaker can be moved out of the way
Move speaker out of the way
Remove 4 18 mm screws (circled in red) from desired key section using Philips #1 screwdriver
Gently push white keys away from screws and pull up to remove from keyboard. Repeat this with the black keys
Reassemble with new/cleaned keys
