Casio Watchband link replacement/repair
Выберете то, что вам нужно
  1. Casio Watchband link replacement/repair, Links: шаг 1, изображение 1 из 2 Casio Watchband link replacement/repair, Links: шаг 1, изображение 2 из 2
    • Locate the hole for the pin you would like to remove.
    • Insert the Sim Card Eject tool (a safety pin may work as well) inthe hole. Make sure to insert in the hole on the back side of the arrow.
  2. Casio Watchband link replacement/repair: шаг 2, изображение 1 из 1
    • Determine the desired amount of links you would like to add or remove.
  3. Casio Watchband link replacement/repair: шаг 3, изображение 1 из 1
    • To remove links:
    • Use the same process used in Step 2 to remove the second link pin.
    • The two link pins and the links should now be detached.
  4. Casio Watchband link replacement/repair: шаг 4, изображение 1 из 1
    • To add links:
    • Push both link pins back into the watch. Make sure to insert the link pin on the front side of the arrow.
    • Lightly tap a hammer until pins are flush against both sides of the watchband.
    • When adding links, be sure to insert the links at the same time as the link pins.
  5. Casio Watchband link replacement/repair: шаг 5, изображение 1 из 1
    • For micro adjustments, push the Sim Card Eject tool into the adjustable side of the clasp. Carefully move pins to the correct fitting holes.
    • Do your best to not let the pins slip outside the metal clasp as they are difficult to get back in.
  6. Casio Watchband link replacement/repair: шаг 6, изображение 1 из 3 Casio Watchband link replacement/repair: шаг 6, изображение 2 из 3 Casio Watchband link replacement/repair: шаг 6, изображение 3 из 3
    • Insert spring into the spring bar.
    • Insert the spring bar pin on both sides of the spring in the spring bar.
    • This is the spring bar pin.
  7. Casio Watchband link replacement/repair: шаг 7, изображение 1 из 2 Casio Watchband link replacement/repair: шаг 7, изображение 2 из 2
    • Put the spring bar and spring bar pins through the end of the clasp.
    • Guide one spring bar pin into the hole on the clasp shell. Hold your finger on the other side of the spring bar to keep the parts together.
  8. Casio Watchband link replacement/repair: шаг 8, изображение 1 из 2 Casio Watchband link replacement/repair: шаг 8, изображение 2 из 2
    • Squeeze the spring bar so it fits within the metal sides of the clasp.
    • Guide the other side of the spring bar into the other hole.
Заключение
To disassemble the clasp, follow the last 3 steps in reverse order.
8 участников успешно повторили данное руководство.
Zach Monroe
Участник с: 09/29/15
336 Репутация
1 руководство автора
Команда
Cal Poly, Team 10-3, Green Fall 2015 Участник Cal Poly, Team 10-3, Green Fall 2015
CPSU-GREEN-F15S10G3
4 членов
Автор 4 руководств
3 Комментариев
These are good tips. Repairing a watch can be tricky especially if moisture creeps in. If you're stuck for help, check out http://TimesTicking.com I have used them many times. Very helpful!
Annette Foster - Ответить
Hi, where can I buy link pins? I have the ones with the spring, but the others - I have not been able to find online.
zhivko.nachev - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 16
За последние 30 дней: 85
За всё время: 11,017
