Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
This is the calculator in question.
Features a black and white dot matrix screen.
Turn the calculator over.
Locate the six screws on the rear of the device.
These are Philips #00 screws.
Once the screws are removed, carefully lift the back panel off, lifting the top end first.
Place the panel to one side.
You can now see the battery.
Now you can insert the new battery
Ensure you place it in spring-first.
Congratulations! You have replaced the battery.
When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
26 участников успешно повторили данное руководство.
3 Комментариев
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
