Введение
The Casio fx-82MS is a commonly used simple calculator in many schools. It has a very long lifetime. But sometimes a button stops working, which can be very annoying. In this guide we will guide you through the steps to fix this problem.
Выберете то, что вам нужно
This is the calculator in question.
The tools you will need are: a Phillips screwdriver, a spudger and a soldering iron.
Flip over the calculator.
Locate the 6 screws on the backside.
Remove all six screws.
Once all six screws have been removed, take the back part off of the calculator.
Locate the rubber contact points.
Solder the rubber contact points, while using the spudger to pry the PCB loose.
Start with the lower plugs (left on the photo). Gently pry the PCB loose at the same time.
If you don't have accessibility to a solder iron, use a utility knife to remove the plugs.
Put the rubber mat back in its place.
Make sure you push the six slightly damaged plugs through the rubber mat.
