Введение
Having problems with the ceiling dome light not turning on? This guide will help you fix the ceiling dome light, if the wiring is wrong.
Выберете то, что вам нужно
Remove the black wire first, since it is the power. Then the white and copper wire.
Once you have twisted the base of the light fixture, the base will come down.
Twist each wire from the base of the light fixture to the wire in the ceiling.
4 участников успешно повторили данное руководство.
