Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Replacing the frame on the Ceiva LF2003 is very easy. No tools are required, and it only takes a few seconds.
Lay the device on its back, and rotate so the base is facing away from you.
Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
Lift up the frame with your fingers and push down the rest of the device with your thumbs.
